Tornado H920 camera and obstacle avoidance issues
I believe I see the number in top right hand corner 65176 is this the number you were talking about?
That should be it. Go into System Settings while bound to the aircraft and camera, then tap about controller. Upload a photo of that screen showing the version information for the controller, gimbal, camera, etc. I’m thinking you nay have an older version of firmware installed.
With it showing 65176 it means the camera is not detecting the full size of the SD card, unless you have a huge amount of data stored on that card. I believe that is showing about 64GB free.
THIS IS PROBABLY true I should update firmware I actually just bought a second Tornado H920 Plus because I feel parts are going to be a issue latter on thank you for the advice I wish there was a club where I could rub elbows and get hands on advice
I won’t be back in Michigan until late April. Too cold for my blood this time of year. Check out the member’s map as there are a few in southern Michigan.
I purchased 2 New H920 plus for the same reason. Thinking on a 3rd. Parts are going to be hard to find sooner or later with this being a Leagacy model.
Plad
